WTB Trade 71 barracuda fenders for 70 fenders, WA state
O5C
I’m converting a 71 Barracuda to a 70 and would like to swap my decent 71 fenders (no gills) for a set of 70 fenders in similar condition.
I’m on the Olympic peninsula of Wa state and willing to travel a reasonable distance. PM me through this site. Thanks!
Deathproofcuda
Seattle, WA
Except for the gills (which came only on 71 Cudas, not Barracudas), aren't 70 and 71 Barracuda fenders the same???
O5C
I’m no expert on 71 cars, but the 70 fenders have a stamped steel mount for the (single) headlight bucket that is spot-welded to the front of the fender.
I believe the 71 fenders mount the dual headlights to a separate piece that is bolted to the front of the fender.
I see the 71 headlight mounting piece is reproduced, but the 70 mount is not. At least, not that I have found.
The aftermarket makes it easy to convert 70 fenders to 71 configuration, but the reverse is not true.
If I’m mistaken with any of the above, I would be delighted to hear it!
413
Sounds about right, and the headlight brackets weld on, not bolted so another step and more time to convert them.
Deathproofcuda
Seattle, WA
Got it. Yeah, you a definitely swimming against the current changing a 71 to a 70, instead of the other way around. Maybe a PNW thing.
Good luck with the hunt.
Mr Cuda
North of Seattle
You can bolt 72-74 cuda single headlight buckets into the 71 fender. Then you will just have to locate the outer headlight bezel trim screws.
I thought about checking inventory and a trade, but swapping problems made me say no.
72 buckets
