Speedo stuck at 65 MPH without cable connected???? Does move past when the cable is spun
Todd Jackson
Hi gang - Just put the dash in and noticed the Speedo won't zero out - stuck at 65 MPH. When I spin the cable one way it will move past towards 70, etc....but when I spin the cable the other way it sounds like it's hitting a "stop." Any suggestions on root cause? Dreading taking the dash back out....thanks! TJ
Uh oh! Sounds like you need a new Speedometer gauge! Regardless the issue, you're taking the dash back out! Sorry for the bad news. Take out and see what happens with the needle.
Challenger RTA, good question. I assumed factory stock. But the new Dakota stuff may be definitely different!
Ronbo73
Dudley, MA
The Dakota digital instrument clusters don't use a cable, they use an electronic signal to drive the speedo. I agree with Xcudame, you will need to pull the instrument cluster out and troubleshoot the speedo.
Todd Jackson
Stock speedo....no electronics....listen out your window....you will hear me swearing as I remove the dash...
If I remove the bolts that hold the cable end of the Speedo - wil that allow the back to come off?
Todd Jackson
By removing the front cover and the two bolts on the back. The speddo comes right out.
cudamark
Sounds like the needle spring anchor came loose or shifted.
Todd Jackson
You nailed it...it shifted then I effed it up. So I bought a new Speedo. And I was able to replace it all by dropping the column and pulling the front of the dash off....
