SOLD 1.5 Ratio Adjustable Aluminum Roller Rocker Package
Claudia
Ohio
Adjustable roller rocker arms are made from aircraft quality, certified 2024 aluminum alloy. Fully CNC machined and anodized for additional durability and corrosion protection. Package comes complete with 2 shafts, 16 rocker arms, 16 adjusters and 16 lock nuts. Additionally, package also includes a complete aluminum rocker hold down set w / bolts, a complete rocker shaft spacer set as well as a plethora of shims to ensure an accurate alignment over the valve stems. Package is used and has around 500 miles on it. Two of the roller rockers have a flat spot worn on them (shown in the pictures with an “X” on them) due to an oil clearance oversight when setting them up. Replacement roller rockers can be purchased for $24.95 each from 440 Source.
$300
