SOLD 1973 dodge challenger
blubyou340
Danville
This has a completely rebuilt 71 340 .30 over .heads rebuilt2.020x1.60 racing s.s. valves roller rockers 1.50 on stock hyd lifters and pushrods. Runs greaat and quiet everything mechanically on car is rebuilt or new .orig interior new headliner with ins. Pad carpet frknt buckets are the hang ten model from a 340 dart .have orig seats the car ran and drove befo re everything was done.never taken apart i did all body and paint and engine assbly. My first complete 3 stage paint took 11 hours .candy amber pearl not perfect but very nice not even cut and buffed. Thats not my bag. 15 total coats from primer.in a small tent .never again!!! New tires ralleye rims and rings. Just drive its smooth and quiet inside.heavaly insulated .just add your flaver and go. Asking 45 k can negotiate the few imperfections. Hang with me im gonna try to insert my 10 pics this car would not take much too be a trailler qqueen .
blubyou340
Danville
Mechanically. Replaced: rear brake drums , shoes, spring kit , cylinders, brake lines front calipers and pads .new gas tank , fuel lines.ebrake cables. Complete rebuilt front steering parts, upper and lower ball joints new camber a. Arm bolts , front shocks rear air shocks. Drive gear linkage grommets replaced , kit down cable, tranny flushed. Set filter resealed , front rear u joints diff seal. Tranny seals orig 2200 stall flushed cleaned rear diff flushed and sealed axle bearings and seals 273 rear gears limited slip posi 489 case 8 3/4" manual foot push winshield spray new avs carb fender tag and a corner of build sheet . it must have had some speacial order paint the vin on dash. Is a b3 and the fender tag never been removed it is original with car . paint code says jy9 dark gold poly mett. And the original vinyl top is a light gold i will get the vin and fender tag pics on here
blubyou340
Danville
Is there a price on the horizon??
Yes, i am asking 45 k this of coarse is always negotiable . it is not perfect, few are . its a start for a dependable nice car. And a real nice 71 340 . alot of care taken with this rare engine same block and heads the t/a used its all orig . not hodge podge mix and match thanks for checkin it out. Somebody is gonna get a nice car. I was gonna turn it in to a 71 T\A I HAVE A SHAKER HOOD. KIT FOR IT
blubyou340
Danville
Bottom block stamped. No:0b432518. Cast 05 - 7- 70. Block side cast no: 2780930. - 340. Dash vin on 73 body. Jh23g3b182005 front pass block stamp. Gw340p32820032 × iron cross and b7 was gonna send the pics and fender tag but figured you wanted 71 340 info do have pics
