426 HEMI PARTS
I will be selling at CARLISLE ROW R- SPACES 27-31
HEADS
Indy heads w/ titanium valves flowed around 380cfm 2000.00
VALVE COVERS
K HEAD ORIGINAL A990 COVERS, TUBES,GASKETS 700.00
K HEAD VALVE COVER GASKETS 40.00
light weight race VALVE COVERS 16 PLUG 100.00
HEMI BLOCKS
KB water block and studs 4.31” 12.5 pistons and aluminum rods 2500.00
Indy Maxx hemi block 8 new sleeves 100% like new all machine work by Bob George 3500.00
Factory HEMI lightened steel block early pro stock owned by Don Carlton bushed all machine work 2500.00
HEMI CRANKSHAFTS
New Kellogg 3.50 and 3.48 pro stock 396” 750.00
four street hemi STD cranks 400.00
RODS
Child's Albert's NEW 7.185”,.990 Mopar pin 500.00
BME NEW 6.86” .990 PIN 500.00
HEMI MOTOR PARTS
MILODON PUMP COVER 75.00
SET OF +.100 VALVES 85.00
ROLLER CAMS 150.00 CAN EMAIL CAM DOCTOR GRAPHS
RARE .003+ MAIN BEARING SET 100.00
ROLLMASTER CAM GEARS AND CHAIN SET 50.00
Hemi rocker stock assemblies 750.00 to1000.00
factory hemi distributors
Factory Crankshaft damper and pulley 300.00
SUPER STOCK ALUMINUM W/PUMP HOUSINGS p/n2536787 75.00
MOROSO 10 QT.STEEL PAN 150.00
\HEMI INTAKE AND FUEL PARTS
426 TUNNEL RAM COMPLETE WITH 6214 CARBS AND LINKAGE
Factory hemi intake 350.00
3 TUNNEL RAMS 200.00
GREG DAVIS SHEET CROSS RAM AND 750 CARBS 2000.00
4 sets 1150 Holleys used
Holley 6214 dominators still have uncut air horns NOS 2000.00 pair
Holley 6214 dominators still have uncut air horns like new slightly used dyno pull only 1500.00
DRIVELINE
Titanium cans
7.5” deep 6.1 cert 3 bolt patterns and starter pockets 1500.00
8.25” deep 6.2 cert 3 bolt patterns and starter pockets 2000.00
Lenco 3 speed trans 1.44 ,1.68 coarse spline like new 2400.00
Lenco 4 speed shifter 250.00
3 DRIVESHAFT LOOPS UNIVERSAL 20.00
2 FOUR SPEEDS “A” BODY 350.00
FACTORY 4 SPEED SHIFTERS 150.00
HURST super shifter w/setback 250.00
IGNITION
2-MOPAR GOLD BOXES P3690726 25.00
MSD RETARD BOXES 8981 And 8982 50.00
MSD 25’ 8.5mm red plug wire 60.00/ 40.00
MSD 31523 HEMI WIRE SET JEG'S 179.00/ 150.00
REARS
Dana narrowed rear housing Billet cap spool w/axles 52" flange 32" spring pads 5.57 gears 750.00
Dana gears sets NEW 3.73 , 4.10, ,4.88 used 5.12 125.00 ..NEW 4.30 175.00
Dana posi unit
9" FORD 4 LINK housing 40" flange to flange w/axles 650.00
CHASSIS
INBOARD SPRING KIT P4120665 129.00/ 85.00
8.75 SNUBBER P3690182 60.00/ 40.00
SHOCKS AND SPRINGS
New KONI SINGLE ADJ REAR 1907SPA 600.00/ 300.00
Used double adjustable REAR 1907SPA 300.00
MANY SETS NEW REAR SPRINGS 110LB 90 LB
HEADERS AND EXHAUST PARTS
426 Sanderson street rod block hugger headers used on dyno have EGT bungs welded in tubes. 250.00
426 HOOKER 2.25 4” COLLECTOR RACE “A” BODY NEW AND COATED 800.00
FLOWMASTER Scavenger Collector C214234400
2.25" X 4'" X 24" JEG'S 140.00 SELL 90.00
FLOWMASTER Outlaw Series Mufflers,Inlet: 4''Outlet: 4''Length: 16-3/4''
JEG'S 90.00 EACH WILL SELL 125.00 PAIR
Flowmaster 954540-10 Delta Force Race Muffler 4.5”
JEG'S 140.00 EACH WILL SELL PAIR 150.00
WHEELS
Super tricks 3.5 5 sets and 15x12 a few sets 150.00 UP PER PAIR
Welds rears different widths and back spaces
Convo Pro 3.5 x 15” 4.5” 15x15 rears full set used 450.00
CENTERLINE WARRIORS 3.5 X 15 NEW IN BOX 150.00
FRONT DRAG TIRES
Goodyear 26” #1964
26 x 4.50-15
Wheel Diameter 15 in.
Tire Diameter 26.00 in.
. Tread Width 4.50 in.
SUMMIT 175 each. sell pair 250.00
Hoosier #522-18095 DRAG FRONT
24.0X5.0X15Front Drag Tire
• Tire Size: 24/5.0-15
• Tread Width: 4.8''
• Approximate Diameter: 23.8''
• Tire Weight: 10 lbs.
JEG’S 150.00 each SELL PAIR 200.00
E BODY CUDA NEW FENDERS, DOORS AND HEADER BY VFN 750.00
E body VFN Cuda cowl hood 10” tall .300.00
DUSTER FIBER GLASS TRUNK new in box 150.00
K&N STUB STACK 1050 85=-0600 20.00
HI BACK BUCKET SEAT FRAMES 300.00
THERMO QUAD CARB 9247S 440 TRUCK AUTO 50.00
THERMO QUAD CARB 9371S 50.00
Mopar RADIATOR B/B 2898 069 XHEAVY DUTY 100.00
CNC DOUBLE MASTER CYL 125.00/ 85.00
SYSTEM ONE FILTER ASSEMBLY 100.00
426 HEMI CUTCH FAN CORE AND NEW FAN AND BLADE 250.00
ALDEN FRONT SHOCKS “A” BODY COIL OVERS 200.00
440 CAM AND KIT STOCK COMP
AIRHEART BRAKE HATS NEW 300.00
JOINT JIGGER STILL IN BOX 180.00
B/B WEDGE ENGINE CRADLE NEW 100.00
E BODY HOOD PINS BRACKETS AND LANYARDS 100.00
MOROSO MECH TACH 52110 NEW 50.00
16 VOLT TURBO START BATTERY CHARGERS 150.00 EACH
HILBORN INJECTION FOR TURBO 1250.00
INDY REVERSE COOLING PLATE 50.00
NOSTALGIA PRO STOCK PARTS FOR SALE
6214 1150 HOLLEY DOMINATORS WITH AIRHORNS UNCUT NEW AND USED
6214 1150 HOLLEY DOMINATORS WITHOUT AIRHORNS
HEMI TUNNEL RAMS,
SUPER TRICK WHEELS,
MALLORY SUPER MAG ONE UNITS
CABLE TACHS,
16 PLUG RACE VALVE COVERS
16 PLUG ACCEL DISTRBUTOR WITH COMPLETE DUAL CRANK TRIGGER ASSEMBLY
E BODY CUDA FIBERGLASS FENDERS AND DOORS BY VFN
SNORKLE HOOD SCOOPS
NARROWED DANA W/AXLES
ASST DANA GEARS
ADDED 6/24
MAX WEDGE INTAKE 3705 CARBS,LINKAGE ,FUEL LINES COIL AND BRACKET SAT ON SHELF FOR THE LAST 40 YREAS
MAX WEDGE BARE INTAKE
FACTORY STREET HEMI OIL PAN NEEDS WORK CXAN SEND PICS MAKE OFFER
GASKETS
P4120247 Head Gaskets IRON HEADS 426 Hemi Thickness: .020" Gasket Material: Steel Shim Fits Bore Size: 4.25"-4.310" 69.99
D-5 intake set
Hemi K head valve cover gaskets 40.00-75.00
4.31" HEAD GASKETS copper sets
HEMI PISTONS
All Venoila
4.31 X 3.85 1.45 CH set of 12
4.375 X 4.150 CH 1.645 ROD 6.96
4.26 X 3.75 1.09 blower?
4.27 x 3.75 12.5 109
4.31 1.436 CH 10.5-1 1.03 PIN
4.34 1.98 CH 10.5-1
