Cratos
updated list 7/21
Going to nationals in Ohio. have 70 challenger parts
Rear end (without center section) all new Brakes, lines, drums, hardware etc. and bearings, drum to drum. $650.00
Steering collum foe floor shift $250.00
door window regulators $100.00 ea.
replacement gas tank $50.00 (less than 1000 miles in the car.)
Carter AVS MO49665 $100.00
Carter comp AFB 9755S 3195 $150.00
2-1/2 down pipes for factory HP manifolds with O2 bung welded in Drivers side. $75.00
Power steering pump and gear with hoses $250.00
set 904 heads with new SS valves, valve springs etc. needs small crakes welded up $250.00 (valves , springs and retainers' worth over $600.00 less than 1500 miles on them.
Please contact me if interested if you will be at the Nats so I can bring what you want. still looking around the shop for more![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
