wsr1961
I picked up a 383 4 speed and there are several electrical issues. I printed out the electrical diagram and have a very limited understanding of electrical issues, but I think I can at least trace wires based on the diagram, to the extent they are reasonably stock set ups after 44 years! As a rookie, I will appreciate any insight you guys have, unless it results in me being electrocuted.
Here's what I have:
First, I also have a 1970 Challenger R/T, and each car has the 3-switch panel to the left of the rally gauges. However, the cuda also has 3 aftermarket indicator lights set in the dashboard. Two of them were not connected to anything and I removed them. I haven't checked the third one yet. I have no idea what purpose they served.
The dome light does not work. I touched the bulb outlet contacts with a circuit tester and the driver's door open, and sparks started flying where the tester touched the contact. I assume power is getting to the outlet but maybe there is a short? Any idea what I should do to try to repair it?
The fog lights are in the passenger floorboard along with about 5 feet each of wiring. They don't help much there. With the wiring diagram, should I be able to reinstall and connect them? Also, what makes them turn on/off? The headlight switch?
None of the fender lights/blinkers work. I frankly haven't even checked them for bulbs. I also have not tested any fuses. Should it be reasonably easy to get them working with the wiring diagram, even if I have to replace the outlets and/or wiring?
Headlights, tail lights, brake lights, emergency flashers, rear and front blinkers and reverse lights all work. However, when I use the right turn signal, the left tail light stops working while the right taillights are blinking. Any idea what that might be?
On an unrelated matter, I removed a valve cover to confirm head casting type and date. I noticed that the valve cover bolts were several different types, some with as many as 4 washers. Without confirming, I assumed they were a mis-matched set of various lengths with the washers used as spacers. So I ordered a set of Mopar big block valve cover bolts, and they also need the extra washers to fit tightly. The valve cover appears to be OEM stock. Is it possible that the thickness of the valve cover gasket is keeping the bolts from seating all the way, thus the need for extra washers? Plus I broke the head off of one of the mixed set of bolts tightening it. That's another problem I have to deal with. It protrudes a bit from the head but pliers won't turn it. I will try vise grips next I suppose.
If anybody wants to swing by and restore everything to factory stock that will be fine. I will even buy you a donut or two. Otherwise, any advice will be much appreciated.
Here's what I have:
