I removed the latch support structure and am replacing it with an AMD repro. Unfortunately, the AMD repro doesn't have the factory threaded inserts for the trunk latch, just holes. So, I cut out the factory inserts and welded them into the repro latch structure. The tail panel and trunk latch structure got damaged (tree fall? IDK) and you can see the rust along the bottom, coupled with the bent-up latch structure itself. I'm trying to repair and use my original tail panel, as the factory flanges that meet the upper qtr panels are more uniform/accurate than the AMD repro tail panel. I also found out the lower portion of the AMD tail panel is shorter than the factory original by at least a half inch, causing original factory spot welds on the rear trunk floor flange to be exposed. Frustrating.
