'71 Barracuda Crossmember
Claudia
Ohio
Can anyone tell me if the transmission cross member is the same regardless if the car is a small block / big block or a manual / automatic setup?
js29
lee center ny 13363
I believe they are all the same. the only thing is early and late E body's won't interchange I think 73@74 cross members are different.
70 is by itself. 71 - 74 are different. As stated, 6 cyl, small block, big block and Hemi are the same.
Claudia
Ohio
So, '71 through '74 e-body are all the same, correct?
No difference between a manual and automatic?
js29
lee center ny 13363
I did have that wrong! my apologies, I did not remember what years were different! Well I wasn't as far off as I was maid out to be!!!
Moparparts
This is correct information
Here are the applications and part numbers for the trans crossmembers. Each part number is correct for automatic or manual transmission
70 E-Body part # 2962074
71 E & B-Body built up to June part # 2962074
71 E & B-Body built after June part # 3583188
72 E & B-Body part # 3583188
73-74 E & B-Body part # 3642794
70-72 E-Body & 71-72 B-Body will interchange but 73 -74 will not interchange with a 70-72 E or 71-72 B
Hope this info helps with your search so you get the correct part
Claudia
Ohio
Perfect information! Exactly what I needed. Thanks everyone!
