FOUND 71 cuda radiator
Rand
I am looking for a radiator for my 71 cuda 383 automatic. I think it's 22 inches #3443938? If i have that incorrect please correct me thanks
There are two different radiator support sizes / openings, you should measure yours. If you are doing a meticulous restoration then stay with the 22; otherwise, if you have the larger opening, I would consider the 26 for extra cooling.
My 71 Cuda was originally a 383 motor and had a 26" radiator. It now has a gen 2 hemi resting between it's 2 front fenders. Make sure by measuring because a 26" rad will keep you cooler.
Mine measures 22 inches. I think for a mostly stock 383 it should be enough. But a hemi would look really nice .
I have the broadcast sheet for my car and the Rad. # on it is 59 which designates the 26" rad.. I guess car was ordered with maximum cooling.
