'74 Challenger w/ 318 ::: MOTOR MOUNT question
rrbbkk
West Michigan
'74 Challenger w/ 318 ::: MOTOR MOUNT question​
This past season I started having a problem when I'd punch the gas in first gear, usually going up hill. I would hear a scraping sound that my mechanic eventually determined was caused by the torque of the motor, no longer held properly tight by fifty year old motor mounts, allowing the engine to "jump" and the fan blade to hit the fan shroud. He said the hard rubber in the mounts was deteriorated and the mounts needed to be replaced.
In researching motor mounts I find a vast array of prices and choices, none terribly expensive fortunately. What does anyone suggest for new, factory style, motor mounts - and where would I get them?
Thank you!
If you look to the right, there are a handful of advertisers. I normally start my search with these folks. For example, you will see Layson's and they have them. I used stock on mine.
