8-3/4 Axle Shafts
stu in wichita
My '74 Challenger has the 8-3/4 non-posi axle. Unfortunately, when I took it apart to replace the bearings and seals, I didn't keep track of which axle shaft came from the left and right sides. Does it matter? I know the bearing adjustment ring goes on the right hand side, but just wondering about the axle shafts themselves.
Are they both the same? The length is the same, and the bearing and seal areas look identical.
I hope someone can advise me.
Thanks for the help.
-Stu
stu in wichita
Thanks. I knew that the adjustment needed to be on the right, but I didn't know if there was a difference in the axle itself.
-Stu
