cuda'parr
I took the 741 third member out of my 71 cuda that had 3.91's and is a spring type posi. I installed a 489 with 3.23's clutch type. Used my same axles but changed all seals, bearings, spacers and gaskets. Torqued everything up and go to set the axle end play and everything is tight. Back off the 5 axle retainer plate bolts 2 turns and I get end play. Is the third member pin that hold the side gears different lengths from the two types?
Any ideas?
Any ideas?
