smitty_040
Yes, I know. Another dash lighting post.….
Trying to track down where things are going off the rails.
1. Continuity - I checked every orange wire from each end point connection and all show continuity back to fuse panel. Checked the brown wire from fuse panel to dimmer and it has continuity. Checked the black/yellow wire from dimmer switch to headlight switch and it has continuity. Checked black/white wire to black/yellow wire and it has continuity.
2. Jumper wires. Eliminating both switches I added jumper wires from the black/white wire to the black/yellow wire on the headlight socket. Then added a jumper wire from the black/yellow wire to the brown wire on the dimmer socket. I show 11.72 volts at every orange connection point.
3. Light bar. When I connect the light bar to the 3 way orange socket and ground the bar to the dash, the lights don’t work. I checked the voltage on the 3 connections on the orange socket and all show 11.72 volts. The remaining two still show 11.72 volts when the light bar is plugged in. Did that to see if the light bar was shorting the circuit.
I then unplugged the light bar and took gator clips from the light bar plug to the battery terminal on the fuse panel and using the same ground, the lights turn on.
I also took a gator clip from my aftermarket gauge pod light circuit to the orange socket and no lights. These also work when plugged into the battery terminal of the fuse panel and using the same ground in effort to eliminate the light bar variable.
I am stumped. No other lights are plugged into the orange wire circuit other than the light bar.
