SOLD B / E-body Parts Lot
Claudia
Ohio
Willing to split up for reasonable offers.
$1,250 OBO
Plymouth Emblem
Battery Tray Support Brace
Horn (set)
Front Shock Mounting Hardware Kit
Lower Steering Column Seal Retainer
Brake Bleeder Screws
Telescoping Antenna Mast
Master Cylinder Brake Lines
Master Cylinder Gasket Set
Manual Master Cylinder Mounting Plate
Two Speed Wiper Motor Wiring Harness
Wiper Motor Nuts
Three Speed Wiper Motor
Main Drive Wiper Arm Linkage
Windshield Wiper Pivot
Front Windshield Lower Corner Trim Molding (LH)
Floor Heat Shield (approximately 6' x 4')
Manual Windshield Washer Pump
Rally Dash Clock Cable
Switch Panel Mounting Plate
Standard Dash Switch Panel Bezel
Rallye Dash Switch Panel Woodgrain Fascia
Rallye Dash Gauge Cluster Woodgrain Fascia
Heater Control Bezel
Metal Interior Trim Set
Automatic Console Top Plate
Automatic Console Shifter Light
Shoulder Belt Retainer Clips
Exterior Mirror Screw Kit
Exterior Mirror Gasket Set
Ignition Switch (missing connector)
Key Buzzer Switch (missing terminal ends)
Ignition Key Lock Cylinder w/ Keys
Window Crank Handle
Interior Door Handle (LH)
Armrest Pull Cup Bracket
Chrome Door Lock Lever (set)
Dome Light Assembly
Vinyl Decal Application Kit (spray and gel)
Door Lock Cylinder Gasket Set (2 gaskets)
Door Lock Link Rod (LH)
Door Lock / Latch Rod Clips
Quarter Window Roller Kit
Coat Hooks
Exterior Rear Lower Window Trim Piece (LH)
Exterior Rear Lower Window Trim Piece (RH)
Exterior Rear Upper Corner Window Trim Piece (LH)
Trunk Latch Striker Plate
Paint Suits
Claudia
Ohio
DALTON - Yes, white interior trim pieces are a complete set of interior (metal) trim for a Challenger.
(1) Front Windshield - Upper Trim Piece
(2) One LH / One RH - Interior Drip Rail Trim Pieces
(4) Rear Window Interior Trim Pieces
Claudia
Ohio
Sorry, I do not . . . it has already been sold.
Claudia
Ohio
Sorry, I had one of each but they have both been sold.
