Claudia
Miscellaneous Gaskets
Valve Stem Seal Set
Mopar Hot Wire Ignition System
Battery Tray Support Brace
Fuel Pressure Gauge
Lower Steering Column Seal Retainer
Master Cylinder Brake Lines
Tach Wiring Harness
Manual Windshield Washer Pump
Rallye Dash Clock Cable
Rallye Gauge Voltage Limiter
Rallye Dash Headlight Bright Switch Light Tube
Switch Panel Mounting Plate
Heater Control Bezel
Rallye Dash Light Bar Lens Set
Interior Upper Windshield Metal Trim
Rubber Sun Visor Tips
Dimmer Switch Grommet
Floor Wiring Cover Set
Headliner Bow Clips
Interior Headliner Metal Roof Rail Trim Set
Shoulder Belt Retainer Clip Set
Exterior Mirror Gasket Set
Ignition Switch (missing connector)
Key Buzzer Switch (missing terminal ends)
Ignition Key Lock Cylinder w/ Keys
Interior Door Handle (LH)
Dome Light Assembly
Vinyl Decal Application Kit (spray and gel)
Door Lock Cylinder Gasket Set (2 gaskets)
Door Lock Link Rod (LH)
Quarter Window Roller Kit
Sail Panels
Exterior Rear Lower Window Trim Piece (LH)
Exterior Rear Lower Window Trim Piece (RH)
Exterior Rear Upper Corner Window Trim Piece (LH)
Trunk Latch Striker Plate
Paint Suits
All parts are B / E-body.
Will sell as a lot or split up.
$275 OBO
Valve Stem Seal Set
Fuel Pressure Gauge
Tach Wiring Harness
Headliner Bow Clips
Dome Light Assembly
Sail Panels
Paint Suits
$275 OBO
