Claudia
Parts are a mixture of new and used. All used parts are in good condition and most have already been media-blasted and primed. If you have questions about something specific, need pictures or measurements please let me know. Please contact me directly if you would like to do a package deal on either the BB parts lot or the E-body parts lot or if you are interested in purchasing everything together and I can work with you on pricing.
Big Block Parts:
Mopar BB Misc Hardware – 25
Mopar BB Valve Cover Gasket Set (rubber) - 25
Mopar BB Valve Cover Gasket Set (cork) - 10
Mopar BB Cylinder Head Springs, Retainers & Exhaust Valves Set - 75
Rocker Arm Shims (vertical and horizontal) - 25
Mopar BB Chrome Valve Cover Hold Downs – 20
Mopar BB Coil w / Mounting Bracket - 20
Radiator Cap – 5
Mopar BB Water Neck Gasket w / Hardware - 6
Mopar BB / 727 Kick Down Linkage - 100
Mopar BB Timing Chain Cover – 50
Mopar BB Water Pump Gasket - 6
Mopar BB Camshaft - 50
BB Fan Clutch - 15
Mopar BB Fuel Pump Pushrod - 20
Mopar BB HP Exhaust Manifold Heat Riser - 120
66 - 72 B-body / 66 - 73 C-body / 70 - 74 E-body LH 440 Engine Support Bracket – 30
Mopar BB Fuel Pump Gaskets - 6
Mopar BB Flexplate – 35
Mopar BB Rear Main Seal Retainer - 25
Mopar BB Oil Pump Shaft - 30
Mopar BB Oil Pump – 40
Fram Oil Filter - 5
Mopar BB Oil Pickup Tube – 20
E-body Parts:
70-71 Mopar Rallye Wheel Center Cap - 5
Mopar Front Shock Mounting Hardware Kit - 10
71 - 74 E-body / 71 - 73 B-body Steering Column Seal Retainer - 18
Mopar Fuel Line Hardware Kit - 15
New, kit is for 3/8” supply line and ¼” return line
E-body Torsion Bar Set - 40
774 bar and 775 bar
Mopar Electronic Ignition Module - 10
70-71 E-body Wiper Linkage Pivot - 50
Floor Heat Shield - 50
Approximately 6’ x 4’
70-72 E-body 4 Speed Brake Pedal Pad - 5
70-74 E-body Standard Dash Light Bar - 50
E-body Rallye Dash Speedometer - 175
E-body Rallye Dash Tach - 175
E-body Rallye Dash Clock - 175
72 – 74 E-body Rallye Dash Lens - 125
70-74 Barracuda Weather Strip Channel Retainer Trim Set - 80
73-74 B-body Outside Mirror Gasket - 10
70 – 74 E-body Ignition Switch - 20
Missing connector
70 – 74 E-body Key Buzzer Switch - 25
Missing terminal ends
70 – 71 E-body Ignition Key Lock - 25
70 – 74 E-body Turn Signal Switch - 25
Missing connector
Mopar A, B and E-body Upper Steering Column Bearing and Insulator - 25
Mopar Window Crank Handles – 6 each
Mopar Late 60’s Interior Door Handles – 10 for both
Have two LH handles
Mopar Dome Light Assembly - 50
Holley Blue Electric Fuel Pump - 100
Mopar Trunk Lid Latch Striker - 20
B / E-body Trunk Lid Latch Striker - 25
Mopar Trunk Lid Latch - 25
70-74 Barracuda License Plate Light Lens – 10 each
70-74 Plymouth Barracuda Fuel Tank Filler Neck Tube - 40
71 Barracuda Chrome Grill Taillight Bezel Set- 50
Big Block Parts:
Radiator Cap – 5
BB Fan Clutch - 15
Fram Oil Filter - 5
E-body Parts:
774 bar and 775 bar
Missing connector
Missing connector
Have two LH handles
