Big Block Parts Lot
Claudia
Ohio
New and used Mopar big block parts lot:
New Misc Hardware
Used Misc Hardware
New Valve Cover Gasket Set (rubber)
New Valve Cover Gasket Set (cork)
Used Cylinder Head Springs, Retainers & Exhaust Valve Set
New Rocker Arm Shims (vertical and horizontal)
New Chrome Valve Cover Hold Downs
Used Coil w / Mounting Bracket
New Radiator Cap
Used 727 Kick Down and Carburetor Linkage
Used Timing Chain Cover
New Water Pump Gasket
Used Camshaft
Used Fan Clutch
Used Fuel Pump Pushrod
Used HP Exhaust Manifold Heat Riser
New 66 - 72 B-body / 66 - 73 C-body / 70 - 74 E-body LH 440 Engine Support Bracket
New Mechanical Fuel Pump Gaskets
Used Flexplate
Used Rear Main Seal Retainer
Used Oil Pump Shaft
Used Oil Pump
New Fram Oil Filter
New Oil Pickup Tube
Used Oil Pickup Tube
$600 OBO
