MOPAR Andy
Looking for some advise. I am having problems with the brakes on my 71 383 Cuda with power front disc. The car stops ok but the pedal is low, soft and not responsive. I have a 70 challenger and a 72 challenger with similar power brake set ups and they both work great and pedal response is fine. The pedal in the 71 cuda just does not feel the same. I have all new lines and wheel cylinders are fine. I replaced the master with a unit I bought from "Bill Rolik Enterprises" . Bill is a great guy, very knowledgeable and very helpful. I have a friend who is very good with MOPAR braking systems. We went through the whole system and found that the bushing on the brake pedal assembly were worn so we replaced them. I am also trying to figure out the correct term or name for this mechanism that connects the pedal to the booster. Some have called it a "Dog Leg" and some refer to it as a "cantilever" brake pedal assembly. I have attached some photos of the assembly. We also notice that the rod in the assembly has been welded at some point in its life, so not sure if the dimensions and geometry are correct or if it is even the correct piece for this vehicle. The booster appeared to be working fine and vacume was in spec, but I did buy a replacement booster from Rock Auto. We found that the booster that was in the car, had a different push rod than the one I bought as a replacement. The width of the eyelit on the replacement booster push rod, where the rod attaches to the pedal assembly, was wider than the one that was in the car, and based on the width of the pedal assembly in appears the newer push rod is the correct width. I have found that this brake pedal assembly is available in aftermarket reproduction but it appears there are different widths of the assembly depending on year and a lot of them won't be correct. I have a call into Wildcat Wreckers to see if they have a used mechanism.
I was also advised that perhaps the bore of the master is not correct. Apparently based on year and model the bore can be from 15/16 to 1 1/8. I was told a bigger bore will raise the pedal and make it "harder". I ordered the service manuals for the car to hopefully determine what is correct. At this point I am not sure if the master, brake pedal assembly and or booster are correct.
I am learning as I go hope I was clear in explaining the issues. Any thoughts or advise from all my MOPAR brake guru's.
thanks
thanks
