68HemiRR
This is a Chrysler 1975 to 2003 A999 TorqueFlite Automatic Transmission
with Torque Converter. It came out of 1988 Plymouth Gran Fury Police Car
that had a HP 318 4bbl engine in it. It worked fine when removed from the
car, and has been sitting under the workbench in my garage for years.
$125.00. Local pickup only. I cannot ship it.
A999 (32RH)
The A999 (later renamed 32RH) was a heavier-duty, wide-ratio version
of the small-frame A904 transmission for use with medium-power V8 engines
and the 3.9 L V6 engine. It was equipped with five direct friction plates.
These automatics had lower first and second gear ratios to allow the
lower-powered engines to provide better acceleration without sacrificing
highway fuel economy. Frequently used today in drag racing.
Uses:
1975-1980 360 (2-bbl)
1984-1989 318 (4-bbl Police)
1994-2003 Dodge Ram Van B150 with Magnum 3.9L V6 engine
1994-2003 Dodge Dakota with Magnum 3.9L V6 engine
1987-1995 Jeep Wrangler YJ with 6-cylinder engine.
1997-2002 Jeep Wrangler TJ with 6-cylinder engine.
Jeep Wagoneer/Grand Wagoneer with the 258ci (4.2L) straight-6
A999 (32RH)
Uses:
