Cleaning out garage, Ford,Chevy,Mopar
6PKRTSE
Misc Mopar Parts For sale:
1-used Blown 426 Hemi blower cam $ 100.00
1-new 94-02 club cab body moulding $10.00
2- new/used std Mopar performance windage trays $ 20.00 ea.
1-new 4.150 stroker Mopar Performace windage tray $30.00
4-used Bullit style 68 Dodge hubcaps $25.00 ea.
1-used E-Body power Steering gear box $100.00
2-used E-Body leaf springs & shock plates $ 100.00
1-used Dana 60 3:54 center section & ring & pinion $ 150.00
1 used 4.0L Jeep auto trans yoke $ 40.00
1-used E-body 727, 8-3/4 driveshaft $100.00
2-used steel crank dampers $ 40.00 ea.
1-used b.b. power steering pump $50.00
1-used 70 cast iron 4 bbl intake $ 40.00
1-used 70 B&E body oil pan $ 40.00
1-used 73-93 p.u. or Ramcharger b.b. trans cross member $40.00
1-used A Body 727 trans cross member $40.00
1-used set 452 b.b iron heads $100.00
1-used 3.750 70 440 steel forged crank $150.00
1-new 3.750 Eagle 8 bolt flange HEMI forged steel crank $500.00
2-used 70 Challanger front side marker lights $ 15.00 ea.
2-used b.b. motor mounts $20.00
1-used set od b.b. main cap & bolts $40.00
1-used tach drive distributor $50.00
1-new P3690936 cam offset bushing kit $20.00
2-new P4876926 HEMI spark plugs (4 plugs per pack) $15.00 ea.
1-new Hemi/b.b. many cam & plug dowel pin kits all mixed together $40.00
15-new P4006767 b.b. / Hemi lifters $5.00 ea. $60.00 for all
1-new PD-17 Durabond b.b cam bearing kit $ 20.00
1-new P4529699 sfi approved b.b./hemi damper $250.00
1-used lot of misc cast iron exhaust manifolds, intakes, oil pans, alternators, starters etc.
1- Most brand new NOS in packages or slightly used (Dyno time only)
-5.7L Hemi fuel injection set ups(5)with throttle bodies, injectors, injector rails, spark plug wire assy's etc $250.00 ea. , Air cleaner box assy (6) $40.00 ea. , Flywheels (7) with hdwe $40.00 ea. , Bell housings (2) $100.00 ea., Complete engine bay wire harnesses (2) $100.00 ea. , idle pulley (5) 15.00 ea., tensioner pulley (5) $15.00 , Exhaust manifolds heat shields (6) $5.00 ea. Emissions tubes $5.00 ea. (2) many bags, boxes of NOS mounting hdwe, clips & fasteners etc.
Misc Race Parts for sale
- 1 ea- new Holley p/n 080770 770 Polished Vacuum secondary street avenger carb. $350.00
- 1 ea- new Holley polished replacement fuel bowl $ 15.00
- 5 ea- new Allstar p/n 86134 24” Gilmer style oil pump or drive belts $ 20.00 ea.
- 1 ea. used NX misc Nitrous dry fuel injection kit in a duffle bag with 10 lb bottle for the sleeper look. Can all be hidden. $ 250.00
- 1 set new Speed Pro p/n R9771+5, 4” bore 1/16 1/16 3/16 ring set $40.00
- 1 ea new NOS Power Shot 4150 flange nitrous plate with gasket $ 50.00
- 1 ea new MSD p/n 8484 All HVC pro distributor rotor $ 10.00
- 1 se new Total Seal 4.310 bore 3.0MM scraper & expander set $ 45.00
- 4 ea new Wilson Manifolds Ford style Throttle position sensors $40.00 ea.
- 1 ea new 2” fan spacer $5.00
- 2 ea new light weight billet alum NASCAR style hood hinges $ 75.00
- 2 ea used 26” x 9.5” Hoosier cheater slicks $ 150.00 / pr.
- 3 ea used 31.5 x 13.25 Goodyear slicks $150.00 for all 3
- 2 ea used IHI RHB5 twin turbo set up $250.00 ea. Will separate.
Misc items for sale
- 2 ea new Jupiter pneumatic 1/8” NPT air pressure regulators & gages $ 40.00
- 1 ea used Cobra trapshooter radar detector, still works $20.00
- 1 ea new 12V cigarette lighter air compressor $ 15.00
- 1 ea like new 6.0 Horse Briggs & Stratton lawn mower, power washer engine $ $75.00
http://photobucket.com/6PKRTSE1 for photo's of the new items.
call 1-313-505-7948 Make an offer on all items. I have no use for any of the items & need to make room.
