Clutch replacement ? for 70 cuda 440 need advice!
sunnymopar
Hi, i am in process of finishing my:
440 stock rebuild on my 70 Cuda!
Ram, Mcleod, Centerforce...ect
It has a stock one now! would prefer one that will be user friednly in traffic,
and NOT so HARD on the PEDAL
Appreciate every one that hat experiences with new replacement clutch,,,
Thanks Sonny
For stock use, we sold New Luk clutch kits with reman flywheels. They are a good quality part, reasonably priced and stocked by most major auto parts chains. Just make sure to have a buddy help you as they can be awkward and heavy to install. Get new flywheel and clutch blots as well. Use a torque wrench and Loc-tite. Make sure to keep all mating surfaces clean, clean, clean. Use rubbing alcohol on the flywheel and pressure plate before you install the disc.
69hemibeep
I second the diaphragm pressure plate for a friendly pedal, just did one in my brothers Challenger. It was a Mcleod but Ive used Luk without problems it all depends on the power plant and how its used.
