Just completed updating my 71 Cuda 383, 4speed to Sniper EFI. I need a continuous 12Vpower source when the ignition is turned on and is not interrupted while cranking the engine. I've found a couple sources, such as the ACC blank on the fuse panel and also the yellow 3 port power source under the dash but both of these interrupt when cranking the engie. The ECU needs continuous 12V power even when cranking the engine. Anyone install one of these systems or can someone tell me where I can find uninterrupted 12V power source activated by the ignition switch?
Scottie43 - Shorting out / disabling the ballast resistor may work, depending on coil selection, but is not required for what you are doing. Using any number of circuits that are at 12v during run to operate a relay between the battery and the EFI would have been my first choice. Check the schematic in the factory manual for your choices to operate the relay. This also assures that you obtain a "clean" power source for your EFI. That said, the ballast resistor is there for a reason. When cranking an engine to start it, the current spike causes a voltage drop. (Power = current x voltage.) During this time, the normal system voltage will no longer be 12v, but something much less – say, 9v, for example. If the coil was powered through the ballast resistor during start, the additional voltage drop across the ballast resistor will reduce coil voltage even further (down to 6v, for example) and your engine may not start. That is why the ballast resistor is bypassed during start, so the coil gets the voltage it needs (9v in this example) to operate properly. Once the engine is running, the supply voltage for the coil runs through the ballast resistor which reduces the 12v to the voltage the coil needs to operate properly. For a stock coil, that optimal voltage is less than 12v by the amount of the voltage drop across the ballast resistor. Bypassing the ballast resistor to provide a constant 12v to the coil will not damage the coil, but only if the coil is designed to operate on that voltage or has an internal resistor that duplicates the voltage drop of the ballast resistor.
