Flchallenger
Have a fresh 512 stroker. Have a pcv on one side with a breather on the other that is not attached to anything. Breather side is blowing small amount of oil out on the valve cover which is dripping on the header. I am thinking I should put a original style breather that plumbs into the air cleaner to provide a vacuum. But I am wondering why not another pcv on the other side and tie them together to the port on the back of the carb. I saw a add for adjustable pcv valve which I have never heard of. And how would you adjust one. How much vacuum should there be. Do you get more vacuum from the carb or the air cleaner. Does it matter? I have the cast aluminum mopar valve covers. On the passenger side it has the cut out for a cap and some of the oil was coming out were the flange holes are on the side. So looked for a larger grommet to cover it and seal it better but couldn't find anything but a pcv valve one. Should I put a regular breather with a oil catch can to the air cleaner? Not sure what to do to be honest. Any ideas on what others have done is appreciated.
