I have two E Body rears out of the cars ready for cleaning and reinstallation. This listing is for one of the rears, the one with 10"x2.5" drums $500 and the one without drum brakes $450 or if you want both, I will take $900 for both.
They measure 56 31/64" outside of flange to outside of flange, center line of flange dimension is 46" and come complete with big bolt pattern (4.5" dia. circle) axles. They are both Sure Grip center sections and are as follows:
With the drum brakes is a 489 Case with what appears to be either 2.76 or 2.92 gears and a pinion snubber that will need a new rubber bumper
Without the drum brakes is a 742 Case with what appears to be either 2.76 or 2.92 gears
I have additional pinion snubbers for the 8.75" pumkins as well as 10x2.5" drum brakes for additional $$. I can also supply you a set proper set of shock mount plates the 8.75" housing if you are changing from a 7.25" rear end again for additional $$.
Please send me a PM if you are interested and include a phone number and I will call you to discuss directly. Thanx in advance, Jim
