FOR SALE Cuda Parts
Claudia
Ohio
$500 OBO - All Mopar . . . mostly E-body.
Valve Stem Seal Set
Plymouth Emblem
Battery Tray Support Brace
Front Shock Mounting Hardware Set
Lower Steering Column Seal Retainer
Tach Wiring Harness
Two Speed Wiper Motor Wiring Harness
Floor Heat Shield
Manual Windshield Washer Pump
Rally Dash Clock Cable
Switch Panel Mounting Plate
Standard Dash Switch Panel Bezel
Rallye Dash Switch Panel Woodgrain Fascia
Rallye Dash Gauge Cluster Woodgrain Fascia
Heater Control Bezel
Radio Surround
Lower Dash Trim Corner (RH)
Rallye Dash Light Bar Lens Set
Interior Upper Windshield Metal Trim
Rubber Sun Visor Tips
Interior Headliner Metal Roof Rail Trim Set
Shoulder Belt Retainer Set
Exterior Mirror Screw Kit
Exterior Mirror Gasket Set
Ignition Switch (missing connector)
Key Buzzer Switch (missing terminal ends)
Ignition Key Lock Cylinder w/ Keys
Interior Door Handle (LH)
Armrest Pull Cup Bracket
Door Lock Lever (set)
Dome Light Assembly
Vinyl Decal Application Kit (spray and gel)
Door Lock Cylinder Gasket Set (2 gaskets)
Door Lock Link Rod (LH)
Quarter Window Roller Kit
Exterior Rear Lower Window Trim Piece (LH)
Exterior Rear Lower Window Trim Piece (RH)
Exterior Rear Upper Corner Window Trim Piece (LH)
Trunk Latch Striker Plate
Paint Suits
SFEbody
Los Angeles CA.
Looking to swap my 70 Challenger standard dash to a Rally, do you have the parts to do so including harness?
