FOR SALE Cuda Parts
Claudia
Ohio
All prices are OBO.
20 - Miscellaneous Gaskets
20 - Valve Stem Seal Set
50 - Mopar Hot Wire Ignition System
15 - Battery Tray Support Brace
10 - Front Shock Mounting Hardware Kit
10 - Fuel Pressure Gauge
20 - Lower Steering Column Seal Retainer
25 - Master Cylinder Brake Lines
15 - Tach Wiring Harness
25 - Two Speed Wiper Motor Wiring Harness
40 - Floor Heat Shield (approximately 6' x 4')
25 - Manual Windshield Washer Pump
50 - Rallye Dash Clock Cable
10 - Rallye Dash Headlight Bright Switch Light Tube
40 - Switch Panel Mounting Plate
50 - Rallye Dash Switch Panel Woodgrain Fascia
75 - Rallye Dash Gauge Cluster Woodgrain Fascia
25 - Heater Control Bezel
30 - Rallye Dash Light Bar Lens Set
40 - Interior Upper Windshield Metal Trim
5 - Rubber Sun Visor Tips
5 - Dimmer Switch Grommet
30 - Floor Wiring Cover Set
25 - Headliner Bow Clips
80 - Interior Headliner Metal Roof Rail Trim Set
75 - Shoulder Belt Retainer Clip Set
12 - Exterior Mirror Screw Kit
12 - Exterior Mirror Gasket Set
8 - Exterior Mirror Gasket
10 - Ignition Switch (missing connector)
20 - Key Buzzer Switch (missing terminal ends)
25 - Ignition Key Lock Cylinder w/ Keys
5 - Interior Door Handle (LH)
22 - Armrest Pull Cup Bracket
40 - Dome Light Assembly
10 - Vinyl Decal Application Kit (spray and gel)
5 - Door Lock Cylinder Gasket Set (2 gaskets)
10 - Door Lock Link Rod (LH)
25 - Quarter Window Roller Kit
25 - Exterior Rear Lower Window Trim Piece (LH)
25 - Exterior Rear Lower Window Trim Piece (RH)
25 - Exterior Rear Upper Corner Window Trim Piece (LH)
20 - Trunk Latch Striker Plate
10 - Paint Suits
