Dana 60 to 8 3/4 Rear swap question
Mopar426power
Ohio
My son is going back to an 8.75 rearend from a Dana 60 in a 70 Challenger 4-speed car, will we need a new driveshaft?
Mopar426power
Ohio
He tells me that length seems OK but has U-joint issues, maybe yokes are different sizes?
Katfish
Palm Bay, FL
There are 2 yoke sizes, Dana would take larger. Make sure the yoke isn’t pulled out too far or you’ll have vibrations
Katfish
Palm Bay, FL
For clarification, the only difference in the yokes would be the u-joint size.
There are small 7260 and large 7290 u-joints
The 8.75 will need a longer DS compared to the Dana.
So you may be ok
https://postimages.org/][/url]
pschlosser
Santa Rosa, California
The OP says he's going the other way, from a dana to an 8.75 which implies they need one longer.
I checked the parts book, and I cannot, for the life of me, find a distinction between propeller shafts on differing rear axles. It all seems listed by engine and transmission.
The length will probably work but it is not right , the slip yolk will be too far out of the trans ,it needs to over 1" longer for the 8 3/4
pschlosser
The parts book shows the propeller shaft lengths for 9.75 Rear Axle, either 727 (auto) or 833 (manual) transmission:
Barracuda #2883774 42.60
Challenger #2883667 44.60
And for the 8.25/8.75 Rear Axle, either 727 (auto) or 833 (manual) transmission:
Barracuda #2883636 43.60
Challenger #2883656 45.60
The Dana 60 9.75 drive shaft is 1.00 inches shorter.
AkBillyBow
Alaska
If I may ask, why would you go from a Dana 60 to the 8.75? I am considering going the other way. Other than putting a car back to it's original state, is there some big disadvantage to the Dana 60? Not bashing anyone, just curious to know so I won't make a mistake I may regret later.
Thanks !!
AkBillyBow
Mopar426power
Ohio
Long story but to answer the question: yes, the Challenger has a 340 and we wanted the original 8.75 rear back in the car.
Dodgeboy
Winnipeg Manitoba, Canada
In drag racing some people will switch from the 8 3/4 to a Dana. The weak link in the 8 3/4 seems to be the location/relationship of the pinion/rearend gear. On a good launch (lots of torque/traction) the pinion will try to climb the ring gear causing the diff to flex @ the pumpkin, breaking gear teeth. Using a pinion snupper helps prevent the flexing. Some guys have this issue, others don't. The Dana has a better location of the pinion gear so this is not a issue. I do not know what torque level or 1/4mile et that will test the limits of the 8 3/4. Seems it could be low 10sec or 9 sec ets
Dodgeboy
I have never understood why it seems like 8 3/4s don't get along with manual transmission's. Does a clutch just shock the drivetrain that much more then a high stall converter?
