the factory suspension can get you a long way , it one of the best designs for the period , much larger T bars around 1.1 " , hollow sway bars with a larger diameter , better shocks like QA1 or Bilstien , preferably adjustable , poly bushings , I usually install C body tie rods , depending on rims you can go to larger disc brakes , multi piston calipers , hydro boost will all help braking . Chassis stiffening firewall braces , Torqe boxes, sunframe connectors , lower rad support brace all help , installing lower control arm plates or making them as I did will stiffne them also better adjustable caster struts . I am not sold on tubular upper control arms , they are lighter & can improve geometery but the often fail around the welds or have issues with the heim joints .
Brad 70 did a whole rework on his front suspension & improved a lot of deficiencys & improved the handling .
