door pull
michael bucklew
is the door pull attached to the door panel, or is it a separate piece held to the door frame by 2 screws????panel fits very goo--test fit--- does the rubber weather seal go on top or under the panel. anything I need to know before final install??
mrmopar340
Shawsville Virginia
The pull cup on the door handle should be screwed down and come apart. I think you have to remove it before the door panel comes off. I can't properly recall cause it's been a while.
michael bucklew
wanted to be sure before everything was screwed in place an then OH NO
mrmopar340
Shawsville Virginia
mrmopar340
Shawsville Virginia
Found a pic on the forum from another person. This is the underside and you can see where the screws actually go. A brace inside the door.
Mr Cuda
North of Seattle
The door pull cup is installed on the door panel with the armrest. Everything is assembled before the door panel is installed, and vise vera.
The door panel comes off with 2 screws through the door cup, and the perimeter screws, Allen window crank and door lever.
