Double axle gaskets?
theshado
Indiana
Working to reassemble axles after a gear change. During disassembly found two axle gaskets stacked between the backing plate and the axle flange on each side, for a total of four. These are the metal/rubber gaskets.
Does anyone know if two stacked is “correct”? Any thoughts as to why double stacked?
Normal is 1 metal between the hosing & backing plate & 1 foam between the backing plate & bearing retainer / adjuster .
Thanks for the confirmation.
I suppose I will reinstall only one on each side and see where that gets me. I still can't figure out why there was two--I never had any issues--but if I have any trouble with end-play adjustment I can always add them back.
