Steve340
Are all E Body clutch pedals the same part? or are there differences?
70 and 71 are the same pedals, Clutch switch is different. 72-74 are all the same.70 Ebody is different. 71 -74 E and B body are the same pedal. The difference in 70 is the pedal shape. They all attach the same and function the same.
Check out Brewers for parts as well.Hi. I wondered if you might know the answer. Thanks for the info.
I want to try a modification to the clutch mechanical system.
Can you supply a clutch pedal, clutch rod and a 340 Z bar?
For 1971.
