put my side glass in today..its not too bad just make sure you put duct tape around those sharp openings..i did and it saved me some scrapes i,m sure.. here' s a quick run down..
[1] regulator in first
[2] front track lower bracket only in..remove guide rail from it [allen bolt]..bolt lower bracket in and snug it..
[3] slide front track onto glass
[4] slide glass into door [see gap in upper metal door frame for track to go into] and tilt it forward as it goes in..hold the front guide track so it does not slide off bottom nylon holder
[5] get front track bolted to lower front bracket [i used an old tape roll to support glass in bottom of door to line up hole]
[6] if you took off any guides on outer door frame put them on now... also put on outer cat whisker now if you are replacing them..
[7] connect glass to regulator [phillips screw up front, ..bolt with washer outside regulator lower slide , washer and gasket under it ] regulator slot slides in on top of washer with gasket
but below washer on the mounting bolt [pinches regulator between them]
[8] slide rear track in thru large hole in door..its really easy and goes right together..kinda sucks getting the top allen bolt back in but not bad..
good luck
good luck
