Mar 15, 2017 #1 Claudia Well-Known Member Joined Jul 23, 2014 Messages 810 Reaction score 6 Location Ohio Rating - 0% 0 0 0 Contact seller Let me know if you see something that you are interested in. All motor related parts have been sold. Mostly e-body parts left.
Mar 15, 2017 #2 brian6pac Well-Known Member Joined Nov 27, 2016 Messages 77 Reaction score 7 Location ohio Rating - 0% 0 0 0 what cam is that?
Mar 15, 2017 #3 DALTON Well-Known Member Joined Jun 1, 2012 Messages 68 Reaction score 6 Location Crystal Lake, IL Rating - 0% 0 0 0 How much for a pair of door sill plates?
Mar 15, 2017 #4 Claudia Well-Known Member Joined Jul 23, 2014 Messages 810 Reaction score 6 Location Ohio Rating - 0% 0 0 0 Sorry, sill plates have already been sold.
Mar 15, 2017 #5 brian6pac Well-Known Member Joined Nov 27, 2016 Messages 77 Reaction score 7 Location ohio Rating - 0% 0 0 0 how much for the cam?
Mar 15, 2017 #6 Claudia Well-Known Member Joined Jul 23, 2014 Messages 810 Reaction score 6 Location Ohio Rating - 0% 0 0 0 Sorry, all engine related parts have also been sold. Mostly just e-body parts left now.
Mar 15, 2017 #7 moparleo Well-Known Member Joined Oct 17, 2011 Messages 7,102 Reaction score 1,886 Location So. Cal. Riverside area Moreno Valley Rating - 100% 2 0 0 Prices of remaining parts still for sale please.
Mar 15, 2017 #8 Claudia Well-Known Member Joined Jul 23, 2014 Messages 810 Reaction score 6 Location Ohio Rating - 0% 0 0 0 Plymouth Emblem - 30 Headlight Bucket - 25 Battery Tray Support Brace - 15 Inner Fender Inspection Cover (LH) - 15 Front Shock Mounting Hardware Kit - 10 Lower Steering Column Seal Retainer - 20 Fuel Line Hardware Kit - 15 Master Cylinder Brake Lines - 20 Manual Master Cylinder Mounting Plate - 40 Hood to Cowl Seal - 18 Main Drive Wiper Arm Linkage - 50 Windshield Wiper Pivot - 45 Front Windshield Lower Corner Trim Molding (LH) - 30 Floor Heat Shield (approximately 6' x 4') - 40 Automatic Brake Pedal Pad - 10 Standard Dash Light Bar - 50 Rallye Dash Switch Panel Woodgrain Fascia - 50 Rallye Dash Gauge Cluster Woodgrain Fascia - 75 Exterior Mirror Gasket Set - 12 Exterior Mirror Gasket - 8 Ignition Switch (missing connector) - 20 Key Buzzer Switch (missing terminal ends) - 20 Ignition Key Lock Cylinder w/ Keys - 25 Turn Signal Switch (missing connector) - 25 Interior Door Handle (LH) - 5 Dome Light Assembly - 40 Vinyl Decal Application Kit (spray and gel) - 10 Door Lock Cylinder Gasket Set (2 gaskets) - 5 Door Lock Link Rod (LH) - 10 Door End Seal (LH) - 12 Door Lock Pillar Seal (RH) - 12 Rear Quarter Glass (RH) - 60 Exterior Rear Lower Window Trim Piece (LH) - 40 Exterior Rear Lower Window Trim Piece (RH) - 40 Exterior Rear Upper Corner Window Trim Piece (LH) - 40 Trunk Latch Striker Plate - 20 Trunk Lid Latch Striker w / Mounting Hardware - 25 Trunk Lid Latch - 30 License Plate Light Lens - 8 Fuel Tank Filler Neck Tube - 45
Mar 16, 2017 #9 moparleo Well-Known Member Joined Oct 17, 2011 Messages 7,102 Reaction score 1,886 Location So. Cal. Riverside area Moreno Valley Rating - 100% 2 0 0 Excellent. thank you.
Mar 16, 2017 #10 Claudia Well-Known Member Joined Jul 23, 2014 Messages 810 Reaction score 6 Location Ohio Rating - 0% 0 0 0 No problem.
