FOR SALE E-body Parts
Claudia
Ohio
E-body Parts Lots
Open to offers on all the following parts if someone can use them.
Valve Stem Seal Set
Battery Tray Support Brace
Front Shock Mounting Hardware Set
Lower Steering Column Seal Retainer
Tach Wiring Harness
Two Speed Wiper Motor Harness
Front Windshield Lower Corner Trim Molding (LH)
Floor Heat Shield
Manual Windshield Washer Pump
Rally Dash Clock Reset Cable
Switch Panel Mounting Plate
Standard Dash Switch Panel Bezel
Rally Dash Switch Panel Woodgrain Fascia
Rally Dash Gauge Cluster Woodgrain Fascia
Lower Dash Trim Corner (LH)
Standard Dash Heater Control Bezel
Radio Surround
Lower Dash Trim Corner (RH)
Rallye Dash Light Bar Lens Set
Metal Interior Trim Set
Rubber Sun Visor Tips
Shoulder Belt Retainer Set
Exterior Mirror Screw Kit
Exterior Mirror Gasket Set
Ignition Switch (missing connector)
Key Buzzer Switch (missing connector)
Ignition Key Lock Cylinder w / Keys
Interior Door Handle (LH)
Armrest Pull Cup Bracket
Door Lock Lever Set
Dome Light Assembly
Vinyl Decal Application Kit (spray and gel)
Door Lock Cylinder Gasket Set
Door Lock Link Rod (LH)
Quarter Window Roller Kit
Exterior Rear Lower Window Trim Piece (LH)
Exterior Rear Lower Window Trim Piece (RH)
Exterior Rear Upper Corner Window Trim Piece (LH)
Trunk Latch Striker Plate
Hooded Paint Suits
