E-body Stuff
Claudia
Ohio
30 Plymouth Emblem
25 Headlight Bucket
15 Battery Tray Support Brace
10 Front Shock Mounting Hardware Kit
20 Lower Steering Column Seal Retainer
15 Fuel Line Hardware Kit
20 Master Cylinder Brake Lines
40 Manual Master Cylinder Mounting Plate
20 Clutch Pedal Support Bracket
18 Hood to Cowl Seal
50 Main Drive Wiper Arm Linkage
45 Windshield Wiper Pivot
30 Front Windshield Lower Corner Trim Molding (LH)
40 Floor Heat Shield (approximately 6' x 4')
125 Black Carpet Set
50 Standard Dash Light Bar
50 Rallye Dash Switch Panel Woodgrain Fascia
75 Rallye Dash Gauge Cluster Woodgrain Fascia
125 Automatic Console Top Plate
60 Rear View Mirror
12 Exterior Mirror Gasket Set
8 Exterior Mirror Gasket
10 Ignition Switch (missing connector)
20 Key Buzzer Switch (missing terminal ends)
25 Ignition Key Lock Cylinder w/ Keys
10 Turn Signal Switch (missing connector)
10 Window Crank Handle
5 Interior Door Handle (LH)
22 Armrest Pull Cup Bracket
25 Chrome Door Lock Lever (set)
40 Dome Light Assembly
10 Vinyl Decal Application Kit (spray and gel)
5 Door Lock Cylinder Gasket Set (2 gaskets)
10 Door Lock Link Rod (LH)
25 Rear Quarter Glass Seals
50 Rear Quarter Glass (LH)
50 Rear Quarter Glass (RH)
40 Exterior Rear Lower Window Trim Piece (LH)
40 Exterior Rear Lower Window Trim Piece (RH)
40 Exterior Rear Upper Corner Window Trim Piece (LH)
20 Trunk Latch Striker Plate
25 Trunk Lid Latch Striker w / Mounting Hardware
30 Trunk Lid Latch
8 License Plate Light Lens
10 Paint Suits
I have placed a price on each part however they are all OBO.
Let me know if you see anything that you can use.
All parts are located in Southwestern Ohio and are available for local pick-up or could be shipped for additional monies.
