Plumcrazy70
Here are some original E body metal body pieces for someone doing a restoration to use instead of using repop stuff. Make an offer on pieces or all of it, I have this posted on CL also.
-1970-71 Dodge Challenger trunk lid. Trunk lid is decent with no rust through, but one rough spot & some bubbling. $100.
-Pair of 70-74 Cuda doors skins good shape original steel, some pin holes on one of them down low. $500/pair
-bottom inner piece to a Cuda passenger door, has the hinge screw holes really nice piece to repair an original rusted door. $75
-70-74 Cuda deck filler panel (piece between back window and trunk lid) original steel. $150
-70 Cuda header panel (piece between front fenders) beautiful original steel, great shape. $500
-70 Cuda grill, has a crack. $450
-70-74 Cuda Disk brake calipers and booster. $400
-70-74 Barracuda dash frame with rough pad. $20
-70-74 Cuda dash complete with base model gauge, has a 74 BS23 VIN tag. $200
-70-74 Cuda e brake assembly and pedal. $50
-70-74 E body rear springs. $200/pair
-70-74 Cuda hood hinges. $100/pair
-70-74 Cuda trunk gutter pieces. $75/pair
-70-74 Cuda torsion bar cross member excellent condition. $300
-70-74 Cuda trunk lid hinge arm. $20
-70-74 Cuda drivers side door with mirror and exterior door handle, small rust spot $300
-70-74 Cuda Right side trunk extension replacement panel. $50(the only non original piece)
-1972 440 with 4 barrel. turns over by hand have not tried to start or pull a head off. no starter or exhaust. $550
-4 speed (3 speed with overdrive) manual transmission. believe it was out of a truck. $250
