70chall440
I am sending a bunch of E body parts down to fall fling with a friend of mine and thought I would provide a list in case someone is looking for something and will be there. I am not positing any prices but I am not looking to retire off these items, not to say they will be cheap but not stupid either. I don't have any pictures to post so please don't ask, go to the show and look at them for yourself. So here goes;
Flat Cuda hood (take off stock one)
Standard E body instrument cluster
Standard E body Inst. Cluster bezel
Standard E body switch panel w/rear defog hole
RH lower E body dash trim (there are 2, one is pretty good, the other needs some work)
72-74 Cuda rear bumper guards
72-74 Challenger center grille (needs a little work on the lower corners)
Cuda front header panel (take off, ok shape but not perfect)
2 E body speaker grilles (one is basically a donor for the other)
96-03 Ram hood chip guard
70-71 E body rear bumper guards (rubber is bad on both)
E body fender turn signals
E body ash tray with frame/mount
E body dash frame (good shape)
70 Cuda dash pad (not horrible, steel core)
E body glove box door w/hinge
**would sell entire dash as a set
E body plastic dash cap (basically new but the hole over the VIN plate is enlarged
70-74 Cuda outer rocker panel (both are new but one has a little cut off one end)
11" chrome rear brake backing plate (for 8 3/4 and I think Dana)
70-75 Challenger Rear corner chrome (one is ok, the other needs work)
70-74 Ebody LH inner fender brace (brand new)
70-74 Cuda LH fender lwr fender patch panel (new)
70-74 Cuda RH fender lwr fender patch panel (new)
72-74 Ebody slap stick shifter complete with tunnel mounts (only missing the trans pivot)
68-70? A/B body AT shifter (functional but rough)
E body LH ext door handle (I think Cuda but not sure)
2 x E body RH ext door handles (1 is for a Cuda I am pretty sure)
5 x Mopar starters (the old style) - I don't know the years, one should be 69/70 I think
70-74 E body battery tray (new)
LH and RH Cuda lower quarter panel patch panels (these are cut off peices, workable but not real nice)
70-74 kick panels (one was drilled for a small speaker)
70-74 Challenger ext tips (factory, ok for a driver)
70 Challenger fuel filler tube (has 1 nipple up near the top)
71-74 E body console complete (decent shape but not perfect, has the normal break)
71-74 console incomplete and has a break
Challenger MAS TA rear spoiler (never mounted)
69 assembled 340 X heads with rocker arms and Edelbrock valve covers
68-70 Satellite instr cluster chrome side trim
E body kick panels with speaker holes (these are brand new)
72-74 Challenger lower valance insert (the plastic part)
2 x 72-74 Challenger lower valance chrome trim (one is ok, the other needs work)
72-74 Cuda lower valance insert (this is the part that the turn signals are on, it is broken in 2 but could be repaired)
Cuda rear valance - Not cut outs (used original)
340 "388" oil pan
Snorkel hood scoop (generic type, was on a hood at one point)
72-74 Ebody seat covers (these are repaired originals and would be ok on a driver)
Well thats all for now, I am not going to reserve anything because I am not going to put my friend out as he is doing me a favor but he will be at the swap meet with all of his stuff and my crap.
340 "388" oil pan
