Bringing these parts. Deals to be had at show without me hassling for shipping
-disk brake swap complete with the desirable 73-76 A-body/73-74 E-body spindles. Has pin calipers. Was off 73 Challenger
$250
- Manual steering box.
$75
-drivers side E-Body w/sway bar bracket. So Cal no rust pits
$100
Other new stuff. P/N's listed
30%-50% off new price
- MSD RPM Activated Window Switch 8956
- MSD 2 Step Module Selector 8739
- Auto Meter 5330 Quick-Lite Shift-Lite, Black 5330
- Auto Meter 5411 Pro-Comp Mechanical Fuel Pressure Gauge, 15 PSI, 2-5/8 5411
- Auto Meter 5426 Brake Pressure Gauge, 2-5/7 5426
- Auto Meter 5427 Pro-Comp Air-Core Oil Pressure Gauge, 100 PSI, 2-5/8 5427
- Auto Meter 5154 Pro-Comp Mechanical Speedometer, 160 MPH, 5 Inch 5154
- Auto Meter 3904 Tach 5" Monster 3904
- Auto Meter 3332 Sport-Comp Water Temperature Gauge 2-1/16" Mechanical 3332
- Auto Meter 5492 Pro-Comp Air-Core Voltmeter Gauge, 2-5/8 Inch 5492
- Auto Meter 3375 Sport-Comp Digital Narrowband Air/Fuel Ratio Gauge 2 1/16 3375
- Auto Meter 5416 Pro-Comp Air-Core Fuel Level Gauge, 2-5/8 5416
- Auto Meter 5437 Pro-Comp Air-Core Water Temp Gauge, 2-5/8 Inch 5437
- electric fuel pressure with hi lo memory 5462 5462
- Super Powershot Nitrous Oxide Systems -Spreadbore P/N 05104-20NOS
- SCE Copper header gaskets 4069
- Mopar Perf R3 4 bolt main cap package P5249669
- Mopar Perf 8 3/4 pinion snubber P3690182
- Mopar Perf Green Bearing Set P5249444
- Mopar Perf SB Tach Drive Distrib P4120701
- Mopar Perf SB Bronze Gear oil pump drive P3690874
- Mopar Perf High-pressure Valve Springs P4120785
- MP Rear Mount Battery Kit P4349500
- Mopar SB late water pump New 95' up
- Cirkit Boss Circuit Isolator 70107
- Stage 8 Locking Exhaust Kit 8915
- Champion Racing Spark Plugs 687
- Champion Racing Spark Plugs 688
- Willwood Parking Brake Caliper Drivers Side 120-2281
- Willwood Parking Brake Caliper Passenger Side 120-2280
- Chrome-Plated Front Timing Chain Cover (1968-91 426 Hemi® and All Big Block) EG-TD9392
- Stereo Noise Filter disc'd S-10-A CL
- Moroso Cast Alum. Electric Water Pump -Modified for SB Mopar 63546
--Complete B-body 66-69 4 piston Bendix disk setup.
$250
-NEW in box 383 air grabber base and lid repro PN 121-AG383
$260
-New K&N air cleaner E-1980 for air grabber
$60
-passenger side 67-69 B-Body w/sway bar bracket. So Cal no rust pits
$100
