Hi Gals and Guys !
So... This is a 1970 Challenger I just bought. These were some of the pictures from the seller.
I bought this car without seeing it for real.
I just saw it on a Norwegian website (I'm in southern-french-speaking-part Belgium so about 1000 miles away from the car location), called the guy, made a videocall to see the car that way, discussed the price a bit, and the deal was sealed.
Few weeks after I received the car here.
I discovered a few unsaid things, the usual stuff when buying without a personnal inspection.... But overall the seller has been honest.
Happy with the purchase.
Now to describe the car :
From factory she had a 383 2bbl with an auto on the column. Factory B7 blue, black interior, black vynil top.
Not a rare car what so ever, but good to know she was a big block and B7 from factory ! Checked the cowl stamped vin and it matches. Good !
Got the build sheet. That's cool too !
I did not know the engine code when I bought it... First thing I did was check that, and of course... it's a 1977 RV engine. Dang it.
I'm not going to cry. The price was right.
Obviously you can see some body work was done recently in Norway (rear quarter pannels), and eventhough I would not say it's a good job, I would not say it's a bad job either. I like butt welds, and there it's overlapped. But at least they did not warped the whole thing.
New front floors, new trunk floor.
New tank and sending unit as well. Other nice thing is that I have a seemingly complete Wilwood front disc kit (not fitted to the car, brand new) ! That's neat.
You E body enthousiasts will also pinpoint that the interior is somewhat incorrect. Dash pad, steering column/wheel and seats are from a 1972-4 E body.
You'll also see that the body pannels are all misaligned. You are starting to get the idea of this car... What I know she was before buying... A car that has been rougly and quickly repainted just prior to beeing sold. Which happenned to be in 2009 when the Norwegian guy bought it.
Pretty common. Lots of European buyer "get got" !
So I pulled the thickness tester and to my surprise, only discovered a few area's where the body filler really is thick. That's the best news so far !
Underneath the vynil, the roof seems to be quite OK except for the back glass corners, like often. very happy with the body pannels actually!
The trans linkage was so badly adjusted that she would NOT hold the Park position. Very dangerous since she does not have the parking brake cable fitted. One time she engaged the reverse just like that when idling, by herself ! Fortunatly I was behind the wheel and nothing bad happened.
Of course, re-adjusting this is the very first thing I did.
Enough spoken.
Here are a couple of pictures of the car in my dusty shed.
(note that lovely clean sink on the upper right side of the picture. the place used to be an old garage. The old man wasn't really into cleaning stuff but it plays a role in the general atmosphere of the place. Or maybe I'm just too lazy to repaint the shop and find excuses. That's very possible too.)
Now the work has started on the car. I'll get to that later.
One thing I can tell already : I want it more sober looking. I'm not really into that white top, white stripe and spoiler - look - unless it's from factory. Which it isn't ! (not even the right spoiler!)
I did a little cranking pressure test because I felt the engine "was speaking pretty loud" for an RV engine and here's what I got on all 8 : 190 PSI !
Pulled the borescope to check the pistons but they seem to be the original flat tops. Heads are 452's. So that's probably just a Camshaft. But the cylinder walls look very nice ! I'll take it !
She does not smoke one bit, the valve train look new... Nice !
My goal with this car is to have a good reliable driver. Not a perfect shiny car (at least for now). I have a Shiny car (the 1966 Pontiac 2 doors wagon you can see in my member intro) already. I'm worried of driving it if the conditions aren't right.
I want the opposite for this car. I want to live with it. Take it to work maybe. Somebody sits on the fender ? I won't get mad.
In other words, I want to enjoy the cr.... out of it. But to make it reliable I have a lot of work to do.
To end this post, wanted to say thanks again for having me on the Forum. I have had the car for now 3 weeks, and along my work on it, you don't know how many answers I've found on different threads up here already.
Long live to the forums.
I know some of you don't really like the idea that these cars aren't on the American soil and I understand that. If that can make you feel any better, few of these are really valuable ones, most of these are very well taken care of, some of these even go back to USA after some time (I know of a real Hemi cuda that was shipped back to USA!)
Cheers
Enough spoken.
Cheers
