Ralph
- Joined
- Mar 5, 2013
- Messages
- 350
- Reaction score
- 71
So I have a 73 Cuda 340 AC car with front disc and rear drum.
Everything is new on the brake side except the proportioning valve ( I am using the original cast iron type since I cannot find a new one)
After bleeding the brakes I have fluid at all wheels but the brakes are very spongy and do not stop well.
So looking for trouble shooting assistance I looked in the service manual and they describe bleeding brakes on this car in a certain way.
Chrysler states to crack a front bleeder first to produce a front failure condition, then to bleed the rear brakes. Followed by bleeding the front brakes. Then applying the brakes to center the brake warning switch.
Does anyone know what position the valve stem on the metering valve stem should be in - mine is in the out position - is this correct or should it be in.
Any help would be appreciated.
Thanks Ralph
Thanks Ralph
