youngunss1987
- Joined
- May 5, 2012
- Messages
- 46
- Reaction score
- 2
I just moved to san diego and looking to go to the track soon but i have made some upgrades hoping to get in the high 11s but low 12s would be ok ..
my 74 challenger is 3400 lbs with me in it i have a 340 with edelbrock heads 63cc 9.5 compression forged eagle crank a deep ported air gap intake from hughes along with a their cam
i am also running a 4 hole 1 HVH inch spacer with a 750 proform dobble pumper and electric fan aluminum drives shaft , pinion subber with gas shocks in the rear , i am also running 3.91 posi with a rebuilt 904 trans shift kit 2500 rpm stall for ignition i running a accel disturber with a revnator ignition box what should i put my rev limiter at ? i have a 26 inch bfg tire on it right now with 15 inch aluminium rims what would be the best tire for traction ? do i need more gear then the 3.91 ?
Intake Valve Lift 1.5 Exhaust Valve Lift 1.5 | .512" .518" |
Intake Duration at .050" Exhaust Duration at .050" | 223° 236° |
Lobe Separation Angle | 107º |
102º | |
Intake Opening at .050" Exhaust Opening at .050" | 9.5° BTC 50° BBC |
Intake Closing at .050" Exhaust Closing at .050" | 33.5° ABC 6° ATC |
