67Goldie
MA 30 Tug Inc Baggage Tractor/Aircraft Tug. You’re buying a refurbished MA 30 Tug. This Unit has a new Remanufactured 300 6 CYL Engine. New Cooling system. Water Pump , Thermostat, Hoses, and Rebuilt Radiator. New Fuel System. Fuel Pump, Carburetor, Lines, Hoses, And Filter. New Shifter and Cable Assembly New Brakes System Parts, Calipers, Pads, Booster, Steel Lines, And Master Cylinder. New Electrical Components. Wiring Harness, Gauges, Distributor, Cap and Rotor, Plugs and Wires and Light Bulbs. New Axle Seals. New Paint and Anti Skid Paint Fluid has been serviced in all Boxes. Oil and Filter replaced. Air Filter New Steering Wheel and Column. Unit is Street Legal for off Airport Use, Has 4 way Flashers, turn signals, and Brake Lights. Has New Horn and Switch. All Parts Pictured on Concrete will go with the MA30.I was a independent GSE Mechanic for years. This was my personal company Tug. I was injured years ago and Tug was put into dry storage. Was just recently removed from storage and all parts installed and reconditioned. Unit has 19.8 hours of run time since refurbished. Tires were new on unit when put into storage years ago but due to sitting in storage they have dry cracks and are serviceable for now but will need to be replaced in future. This Ma30 starts, stops and runs like a New Machine and ready to go to Service for your Towing or airport GSE needs. Please view pictures for all details and conditions. $3650 |
