gzig5
What have you guys found to be the minimum vacuum level at idle to make the E-body OEM power brakes function correctly? In this case it is a 73 Cuda. I think there have been different boosters over the years and the one in mine is pretty large diameter. I just finished the build on the engine and I'm fairly certain that I'm going to be close to the limit if not under water. I've got an inquiry in to the builder because the data on the dyno sheet was limited due to issues they were having. Engine is stock stroke 340 with a 242/247 duration cam which made 430 lb-ft at 4300rpm and 458 hp at 6300. Peaks should actually be a little higher but they had to change carb and did zero tuning. I'm guessing I'm not going to have much more than 10" but I've never run a cam like this. Trying to get a head start on looking into vacuum canisters/pumps, or hydro-boost.
