moper
All are in Eastern CT, 06237, town of Columbia. Pictures by request. Can ship world-wide for crating/shipping costs or can drive up to 200 miles for gas/cheeseburger money to meet you. Also can provide complete performance and restoration services by former ASE Master Tech, mild to wild, tune ups to full restorations, references available.
Small block New head gaskets: Felpro 8553PT (1pr) $15.00/pr
'65 273 long block. Stuck fast - no oil pan, valve covers, or rockers included but does includes 2bbl intake, timing cover, balancer, and iron water pump - $50
'69 383 shortblock - Pop up forged pistons, std bore, turns with socket, needs freshening - $500
'70 340 block - numbers not visible (rusted away) - cleaned and magged, 1 bore sleeved years ago, std bore, surface rusty - $400
'67 383 block - magged, std bore, rusty - $100
'76 400 block - std bore - $300
'74 440 cast crank - haven't measured but should be std/std & looks good, will include balancer - $100
'76 360 cast crank - needs turning/polishing, currently M.010/R.020 - $50
273 mechanical rockers, shafts, and pushrods - $200.00
Core set of 340 rods - $40
Slant 6 oil pan - $25
64/65 273 cast iron marine 4bbl intake - $40
Core set of RB "LY" rods - $20
Core set of B wedge rods - $20
Take off small block HV oil pumps - (2) $20/each without pickups.
'72 Thermoquad cast iron intake - $50
late model 360 4bbl modified with W2 bolt pattern - $25
'65 A904 trans core - no cables, with flange output & small input & matching stock convertor - $200
