Misc Mopar/race parts for sale-MIch
6PKRTSE
Engine:
1-used Blown 426 Hemi blower cam $ 100.00
1-used set 452 b.b iron heads $100.00
1-new 3.750 Eagle 8 bolt flange HEMI forged steel crank $500.00
1-used set of b.b. main cap & bolts $40.00
1-new P3690936 cam offset bushing kit $20.00
2-new P4876926 HEMI spark plugs (4 plugs per pack) $15.00 ea.
1-new Hemi/b.b. many cam & plug dowel pin kits all mixed together $40.00
15-new P4006767 b.b. / Hemi lifters $5.00 ea. $60.00 for all
1-new PD-17 Durabond b.b cam bearing kit $ 20.00
1-new P4529699 sfi approved b.b./hemi damper $250.00
1-used lot of misc cast iron exhaust manifolds, intakes, oil pans, alternators, starters etc.
1-used 70’ 440 iron 4 bbl intake- $40.00
1-used 70 4 bbl carb linkage & kick down $30.00
1-used 70 440 power steering pump $40.00
1-used 70 iron water pump housing $40.00
2-used 70 440 upper & lower motor mounts $ 50.00 per pair
1-used d.s. lower motor mount bracket $20.00
1-used set of 4 groove water pump pulleys $ 40.00/set
1-used 440 oil pump $10.00
1-new set Speed Pro p/n R9771+5, 4” bore 1/16 1/16 3/16 ring set $40.00
1-new set Total Seal 4.310 bore 3.0MM scraper & expander set $ 45.00
1-used 440 valley tray $10.00
2-used sets of std 440 pistons w/ rings & pins $100.00/set
1-used set of 440 LY rods $100.00/set
2-used 440 distributor w/ vac adv. $10.00
Ram:
1-new 94-02 club cab body moulding $10.00
1-used 94-02 tail gate handle & hardware, everything but tail gate shell $40.00
1-used 94-02 front license plate bracket $25.00
1-used 94-02 day/night rear view mirror $25.00
1-used 76-93 B.B. truck trans cross member
B-Body:
4-used Bullit style 68 Dodge hubcaps $25.00 ea.
1-used B-Body transmission cross member $40.00
1-used chrome master cylinder cover $10.00
1-new pair of lift off hood brackets $60.00
E-Body:
1-used E-Body power Steering gear box $100.00
1-used E-body 727, 8-3/4 driveshaft $100.00
1-used E Body trans cross member $50.00
1-used E Body heater core assy $150.00
2-used E Body rear leaf spring brackets $40.00
A-Body:
1-Used A body transmission trans cross member-$40.00
Drivetrain:
1-used 4.0L Jeep auto trans yoke $ 40.00
1-used 727 trans yoke $ 40.00
Call 1-313-505-7948 Make an offer on all items. I have no use for any of the items & need to make room.
