Missing Fender Tag
Doode
Whom would you recommend contacting to have a replacement fender tag made? Mine is missing and my broadcast sheet was used to make a rodent nest...... Doode
Rich G.
Datatags.com can make a tag. But without documentation you won’t know exactly what should be on it.
aussiemark
Perth Western Australia
Who ever makes it will need to put a VON on it and if you haven't got it you can't guess because you could put someone else's number and then what? you could guess the SPD date going off the door sticker but what's the point if it's not correct it doesn't matter how close it is. Unless you have a build sheet or even better the original tag it is a waste of time.
