jamesroney
- Joined
- Oct 29, 2014
- Messages
- 5
- Reaction score
- 3
Help. I am working on my 1970 'cuda with the 383 / 4 speed. This has been an on-going problem since the restoration several years ago.
The car runs sluggish and hot. I restored it using the original Holley 4bbl, and 906 heads on a standard bore 383. 26 inch radiator, 3.55 gears, Accurate Exhaust. Compression is right at 140 per cylinder, +/-2%.
It never ran right. It just gets hot (220F on a manual gage) Will only create 18 in-Hg of vacuum. AFR sits right at 13.8. So I thought it must be the camshaft, or cam timing. So I changed the cam to a lower profile HP cam. The I change the cam again to a 2bbl "L" code cam. Same result. So I changed the intake from factory to a Weiand. Then changed the heads to Edelbrock aluminum. Then changed the ignition to Mopar Electronic. Then changed the carburetor to a known good Holley 600, then tried an AFB. Then changed to an FITech EFI. Same or similar results in all case. Base timing has been set everywhere from 8 BTDC to 18 BTDC Vacuum advance is functional, an mechanical advance is also working.
I drove a stock 1970 Challenger 340 for comparison, and it ran amazingly better. I'm not talking performance. Just drive-ability and cruise. It's very strange.
But I noticed that the exhaust sounded kind of raspy and whistle-ly. I got my IR pyrometer to check for exhaust temp. I was surprised to see that my cast iron exhaust manifold surface temperature is sitting over 600 degrees F. I made the same measurement on my Bronco, and the highest temp was about 450. So I thought that was strange. I'm starting to think that my resonator / muffler is blocked, or baffled or restricted.
Can SOMEONE factory HP manifolds and a temperature gun PLEASE tell me what your under-hood manifold temperature looks like when the engine is idling at operating temperature?
Any opinions are welcome.
