FOR SALE MOPAR 8 3/4" Center section 4.10 ratio w/ clutch-type sure-grip
Hemihead2
Used factory 8 3/4" suregrip center section. Early X case equivalent (1964). Factory 4.10 ratio with clutch-type sure-grip. Comes with new pinion seal to install. Appears to have correct backlash, nice ring-gear wear pattern. Axle button is in place. Small yoke. $650 or offer. Located in Pa.
Hemihead2
The actual last three numbers on the case (from memory) are 963. There is no X or anything where it normally is. I haven't taken this one apart but historically the early cases were also a smaller straight shaft just like the 741 pinion. My guess is that this was removed from a 4WD truck hence the 4.10 R/P. I don't know of any pass car in 1964 that came with an optional 4.10 gear set.
plymouthbelvy
Aurora,Nebraska
Ah,thanks for the info.I was trying to learn something.Thanks,Mike.
NoCar340
Upper MI
The early (through 1964) 741/X equivalent is the 1820657 case. The one you've got for sale here--should be a 1634985--is the stronger early 742 equivalent (1.75" pinion shaft, also through '64). I've got one of each, both of which I've disassembled to verify that information myself. It's actually a gem of a center section.
I hope that helps with the sale.
NoCar340
Upper MI
He makes no mention of the 1634985 case whatsoever, though, so there's one glaring omission. Mine is a 2.94 open; it was removed from my friend's '64 Imperial Crown Coupe.
