Mopar Big Block Parts
Claudia
Ohio
Need to move these . . . contact me if you would like to do a package deal on everything and I can work with you on pricing. Open to trades for needed E-body or 440 parts.
Mopar BB Misc Hardware – 25
Mopar BB Valve Cover Gasket Set (rubber) - 25
Mopar BB Valve Cover Gasket Set (cork) - 10
Mopar BB Cylinder Head Springs, Retainers & Exhaust Valves Set - 75
Rocker Arm Shims (vertical and horizontal) - 25
Mopar BB Chrome Valve Cover Hold Downs – 20
Mopar BB Coil w / Mounting Bracket - 20
Radiator Cap – 5
Mopar BB Water Neck Gasket w / Hardware - 6
Mopar BB / 727 Kick Down Linkage - 100
Mopar BB Timing Chain Cover – 50
Mopar BB Water Pump Gasket - 6
Mopar BB Camshaft - 50
BB Fan Clutch - 15
Mopar BB Fuel Pump Pushrod - 20
Mopar BB HP Exhaust Manifold Heat Riser - 120
66 - 72 B-body / 66 - 73 C-body / 70 - 74 E-body LH 440 Engine Support Bracket – 30
Mopar BB Fuel Pump Gaskets - 6
Mopar BB Flexplate – 35
Mopar BB Rear Main Seal Retainer - 25
Mopar BB Oil Pump Shaft - 30
Mopar BB Oil Pump – 40
Fram Oil Filter - 5
Mopar BB Oil Pickup Tube – 20
Luis
Radiator Cap – 5
BB Fan Clutch - 15
Fram Oil Filter - 5
Power steering pump pulley for 1970 383 barracuda ?
Claudia
Ohio
Luis,
I do not have any pulleys for sale.
